302 Blocks
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
302 Blocks
How much do virgin 3970010 blocks sell for? (This is the 1969 Z28 302 4 bolt main motor). How much if it has been bored .030 over already?
Brady
Brady
Car: 4
Engine: 6
Transmission: 5
3970010 is one of the most common of all 350 blocks. Lots and lots of them came in trucks especially, all the way through the 70s; truck ones were usually 4-bolt-main.
Check the casting date. Out of all possible 010 blocks, probably less than one-tenth of one percent were 302s.
thanks
Car: 88 Iroc
Originally posted by NTChrist
I don't think there was any way to discern 302 blocks from the other sizes that used 010 blocks, was there?
Looks like the smilie in your sig has bad gas, or something.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
302, 327 and 350 all used the same blocks in '69, thats what i've been told.
Car: 88 Iroc
correct...I should explain about that long pad stuff, thats to all older( I think pre 73) blocks...but yes the 302, 327 and 350 from 1969 all used the same casting number, not too sure on the 67 and 68 Z's
skinny z
Oct 5, 2015 06:23 PM
