fuel pump question
Old Mar 14, 2003 | 05:02 PM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
fuel pump question
I have a mechanical fuel pump that I suspect is bad. When I'm gunnin' on down the road the car starts to miss or bog then pick up for a second then bog or miss again and it's a pretty even pattern off bog and go, bog and go. This usually happens at high RPMs or under severe load only. Any suggestions?
Old Mar 14, 2003 | 05:28 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Umpteen years ago I had an '81 GMC 1/2 ton, auto, 305. It was doing the same thing. It'd be fine up to about 3500 RPM then, "blah, vroom, blah, vroom". I felt like a damn jigabo.
The local GMC dealer wanted ~$400 for a new 2V Rochester carb. I said...... F_ _ _ THAT!!!! I went to NAPA and got a rebuild kit for $35. Didn't help.
Next thing I did was buy a $35 fuel pump, and WHOLLA!!! No more jerky.
First thing I'd check is the basics. Filter, vacuum hoses, float level, blah blah blah. The cheapest is sometimes the easiest.
Old Mar 14, 2003 | 07:10 PM
SkyWarrior's Avatar
Engine: 305 LG4
I recently rebiult my carb, and this still happens, I also bought a new pump only 1 1\2 years ago. But it's only like 12.00 so I'll go get a new one tonight and put it in.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
