ECM problem
ECM problem
I was driving home from work last night when the service engine light went on. I pulled into my driveway and checked for codes. It flashed the 12 about four time which is annoying because it runs bad and won't give me a code. But then the light stayed off, then flickered a little then stayed on for a little bit, then flickered off. The fan turned on and off. Do I just have a bad ecm? I've had a problem with the SES light and not getting codes for a while, but it's gotten much worse recently. Any help is appreciated. It's a 1986 Trans Am 305 tpi
I just don't know why when trying to get codes the SES light flickers irradically. I know there is one flash, a pause, then two flashes, a pause, and it's supposed to do that. The light looks like it's breaking contact though. The fan kicks on when you get codes, but when the light does this the fan turns on and off with the light. And this doesn't happen every time I drive the car. Also when the SES light does go on while driving and I turn the car off I hear the fan kick off. Which it wouldn't do since the car doesn't heat up past 190.
