Vavle train
Old Mar 16, 2003 | 12:02 AM
cutlas-freak's Avatar
Vavle train
yeah i have working on this car for the past few dayz.its a 82 monte carlo and there was a 350 in it and they said it wouldnt run so i try'd everything and finally found out that the timming gear and chain where 6 teeth off so i fixed it and then started it and it missed very bad and then found 6 bent push-rods so i replaced all of them, now it runs but ,isses on two cylinders and i tested them and all the others have 125psi and #3 and 8 read absolutely 0psi wat the problem
please help i dont know if its a bent valve or wat so if you can help me i would apprieate it
Old Mar 16, 2003 | 12:25 AM
radiateu2's Avatar
bent pushrods???? probably have a few valves too maybe a hole in the pistons. Somebody did a number onthat engine. If I had found bent pushrods I would have pulled the heads. Especially if the timing gears where off that much.
Vintageracer
Jan 10, 2020 05:33 PM
Hawk312
Aug 22, 2017 08:55 PM
bjpotter
Oct 4, 2015 07:48 PM
roysatikas
Sep 22, 2015 08:15 PM
g.l.mos
Aug 22, 2015 12:02 AM
