fan help asap
Car: 1987 Z28 Camaro
Engine: 305 tpi
fan help asap
ok, everytime i hook up my fans, my altenator puts out like 8 volts, well i got my battery and altenator check out and they are both working properly, what could be causing that??? and also, my batter leaks charge it seems like, so its losin it somewhere, what could this be?
Car: 82 Z-28
Engine: 383 TPI
A bad rectifier can do that. If one of the diodes inside has opened, the alt will put out the correct voltage but, will lack current output. If a large load is applied, the voltage will drop.
When the alt was tested, was it load tested??
