Toasted Lobe
Old Mar 16, 2003 | 09:06 PM
383GTABoy's Avatar
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
Toasted Lobe
Just finished pulling my cam out and as i suspected the 9th love back is almost completely round and the lifter is about 1/8" shorter than the rest. The rest of the lobes look great. ill be ordering a new cam in the morning but i dont want the same thing to possibly happen the the new cam. What could of have caused this after only 250 miles. See sig for motor specs. The cam was a small base cam because the cam i tried to install before it hit my rods. I installed new springs and lifters with it too.
* Advertised duration: 268 intake/280 exhaust
* Duration at .050 in. cam lift: 224 intake/230 exhaust
* Gross valve lift: .479 in. intake/.480 in. exhaust
* Lobe separation: 112 degrees
Old Mar 17, 2003 | 05:36 AM
ede's Avatar
ede
inpropper break in, lack of lube, to stiff valve springs, rocker adjusted to tight, push rod length might of been a factor
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Jorlain
Oct 8, 2015 01:57 AM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
J.C. Denton
Sep 21, 2015 04:23 PM
