Speedo & heater, A/C questions....
Old Mar 17, 2003 | 05:25 PM
84 Challenge's Avatar
Have a few small problems with my 83 Z.
1. Speedo/odometer is not working. Cruise is not connected as I'm running a non-CC carb. Does it need to be connected for the speedo to work? There's also a few cruise vacuum lines that doesn't go anywhere. Speedo cable is connected to cruise and tranny. Anything else I can check?
2. A disconnected vacuum line was found at the HVAC canister by the brake booster. Re-connected it to the carb. Is this ok? Heater/fan only works in "high" mode in defroster and dash vents. Will not work in any other speed. Air will only come out the vents while the engine is running. Not running...in defroster only. What else is up?
Thanks,
Brandon
Old Mar 17, 2003 | 11:36 PM
Common guys! I know next to nothing about vacuum lines. Any help would be appreciated.
Thanks,
Brandon
Old Mar 18, 2003 | 03:48 PM
TTT
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
