fuel pump
Car: 1978 Chevrolet C10
Transmission: Turbo 350
fuel pump
ok i just picked up a 87 formula and i wanted to put in a carbed engine with a mechanical fuel pump, but i was wondering, the car came with TPI and i was wondering, do i have to put in a carbed engine's fuel tank/pump, or can i just pull the fuse for the electrical pump and just use a mechanical pump on the side of the engine?
what would i have to do to get this to work?
thanks for any info.
Shean
Shean
Car: 4
Engine: 6
Transmission: 5
The L98 & LB9 cams have a fuel pump lobe. IIRC the block still has the boss for it too. I've heard of blocks that didn't have the passage drilled for the rod, but I've never seen one like that. If yours has that, then it should just all bolt right up.
Alternatively, some people have been able to use the existing FI pump, and get a 3-port regulator (high pressure in, low pressure out, & return) to work; as long as you can set it down to 5 psi or so, and not have it spike up to more than 7 psi ever at any time, that should work fine too.
thats what im wondering, everything that is computer controlled that has to do with the engine is gone. ive got vacume advance distributor, non computer controlled edelbrock carb, and some other junk. i just got a temp cencor and a oil pressure.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
