Help! My hatch wont close all the way.
Old Mar 27, 2003 | 11:28 AM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
yo, my hatch motor wont pull my hatch all the way down. its like its burnt out. Help, what can I do? Where Can I get a new one. I was told those motors are disscontinued.
Old Mar 27, 2003 | 11:32 AM
CrispyClutch's Avatar
Usually its the clear plastic case that holds the mechanism together that gets cracked and broken.
In my case the screws that hold it to the trunk had worked loose and wouldnt hold... I went to the hardware store and got some epoxy based glue called Liquid Titanium and slathered it in the holes so the screws would stay...a year later, still works fine!
As for the motors, they rarely actualy burn out, more likely the fuse. If the motor really is dead then just go to your local junk yard for a new one.
Old Mar 27, 2003 | 01:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yo , it might be a simple fix.
The hatch motor raises and lowers. It's known to get stuck in the down position, including mine. There is a little lever that you push down on if this is the case, it will raise the motor back up and work fine.
Worth a shot.
db057
Apr 28, 2019 07:45 AM
punkmaster98
Sep 30, 2015 11:01 AM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
corey8084
Sep 17, 2015 02:56 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
