Cam's For A 400 small block
Old Mar 30, 2003 | 02:37 PM
cubedhead's Avatar
I have an 87' Trans Am and im going to put a 400 small block in it soon and i want to know, or get some ideas, on cam's. I wanna have this car run mid 13's be able to have this for a street driver also.
Old Mar 30, 2003 | 03:08 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
what gearing???
is this going to be a daily driver that has to pass emssion?
Start with something like an comp XE274
Old Mar 30, 2003 | 03:27 PM
cubedhead's Avatar
it has 3.10 gears and what would change if i had to get it checked??
Old Mar 30, 2003 | 06:15 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
a milder cam profile might be required depending on emission. Something like a comp XE268 MIGHT pass.. but the 274 would probably not.
3.10 gear is pretty strange.. most were 3.08..
I would go with a 268 probably.
Old Mar 30, 2003 | 08:44 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
you didnt say what your doin about heads so that will play a role aswell..
for a daily drivin 400 id say get a cam that would be "hot" for a 350...
ive seen a few dynos of different 400s using a cam with less the .500 lift makin 450+ horse...
if your worried about emissions then go with smogger headers, hi-flow cat and a 4 inch exhaust
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
