paint on one primary tube burnt to a lighter color?
Old Mar 30, 2003 | 08:12 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
well, when we first started up the new engine, the paint on one of the primary tubes changed from black to light gray due to heat. it is cheap paint from $110 hedman headers, but if that was the only factor, i would think all of them would have been affected. what do you think caused this, and how do i fix it? or should i just leave it?
Old Mar 30, 2003 | 08:58 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Could be that one cylinder went lean and ran hotter. I'd definitely fix the problem before you drive it too much more and melt a piston. Look for vaccuum leaks. They will cause a lean condition in a sinle cylinder.
Old Mar 30, 2003 | 09:11 PM
Momar's Avatar
If that is the paint that came on the headers it is for shipping purposes only. It will burn off to bare metal soon. It is not made for high temps, but just to prevent rust till it gets to you when you can do whatever you like with them.
Ben
Glowsock
Jul 24, 2025 03:15 PM
69 Six Pack
Oct 5, 2015 07:51 PM
LT1Formula
Aug 20, 2015 09:36 PM
beast94
Aug 20, 2015 06:44 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
