Swapping axle sbetween 3 and 4 gen cars?
Old Apr 5, 2003 | 12:01 AM
Tailmaphas's Avatar
Car: 87 Pontiac Trans Am GTA
Engine: tpi 355
Transmission: t56 6 speed manual
Axle/Gears: 9 bolt 3.90
Does any one know if you can swap 4th gen axle shafts into a 3rd gen(84)? I know 4th are 28 spline and early 3rd are 26. Also, can you interchange ring and pinion gears from early 3rd gen carrier (7.5) to late 3rd gen/4th gen 7.625 carrier. Any factual info would be appreciated.
Tailmaphas
Old Apr 5, 2003 | 05:53 AM
ede's Avatar
ede
length is differant
Old Apr 5, 2003 | 08:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, the axles will not interchange. The gears will. All of these rears from 77 to the present use the same gears.
Old Apr 6, 2003 | 07:12 PM
Tailmaphas's Avatar
Engine: tpi 355
Thanks for the info.
midge54
Dec 27, 2019 04:14 PM
jharrison5
Aug 19, 2015 05:53 PM
reiderz iroc
Aug 13, 2015 04:57 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
