high crankase pressure on a 406
Old Apr 8, 2003 | 09:15 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
what causes high crankcase pressure? i had alotof oil leaks on my fresh motor, i would fix one and something else would start leaking, i finnally figured out it was high crankcase pressure when i pulled my dipstick and it had pressure, i think i got it fixed by putting a valve cover breather on it, and keeping the other side a pvc valve.
Old Apr 8, 2003 | 09:29 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That's correct. You probably got it fixed by putting the breather on.
Old Apr 8, 2003 | 09:46 PM
camaro03's Avatar
Car: 1982 camaro
i know i fixed it with that, but my previous 305 didnt do that, is it just natuarl with the bigger bore and longer stroke of the 400 or could there be something worng? thanks
bryanwood74
Sep 24, 2015 09:50 PM
mddaniel
Sep 8, 2015 05:16 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
TA8487
Aug 16, 2015 12:21 PM
