fuel tank sucking air...
Old Apr 15, 2003 | 07:09 AM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
I notice every time I remove my gas cap, I get this rush of air into the tank, like the tank is under vacuum. It sucks air for several seconds, not just a quick rush of air. What could be causing this? The car is a 89 TPI 350.
I tried a search, but couldn't find anything that really sounded like the same problem. It is definately not under pressure, and I have checked the tank vent (right in front of the rear axle) and it appears to be fine. Needs a bit of pressure (normal???) to expel air, but it does open.
Old Apr 15, 2003 | 07:18 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
It may have something to do with your vacuum canister, which is located in the opposite corner of your battery in the engine compartment. Just my opinion.
Old Apr 15, 2003 | 08:16 PM
Engine: 5.7L TPI
If it's the vacuum canister, am I looking for any typical cause or trouble spot, or is the whole thing likely shot?
Old Apr 16, 2003 | 06:06 PM
427camaro's Avatar
Engine: 4.0L DOHC
Like I said, it's just my opinion, but:
Mine did/does this, check the connections on the canister.
Old Apr 16, 2003 | 09:23 PM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
does it really cause a problem? mine does the same thing and i was wondering what it was...
Old Apr 16, 2003 | 09:42 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Mine does the same thing. When I uncap the gas tank it hisses for acouple seconds. I talked to some other people I know and their 4th gens do it also. I'm not to concerned over it.... my a/f ratio pretty normal
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
BurlyChev
Aug 16, 2015 09:08 PM
