New-HollyFuelPump=Car-Dies???
Old Apr 19, 2003 | 12:02 AM
88CRUZIN's Avatar
Hey,guys,i,gotta,prob,here!
ok,i,got,this,new,Holly-mech.fuel
pump-today.So,i,go,to,put-it-in.
Well-i-hook-it-up-NO-leaks-nutin.
i-crank-the-car-to-start,and-nutin.
the-car-dies-if-i-take-my-foot-off
the-gas.i-can-see-fuel-going
through-the-fuel-filter-barely.
the-filter-doesnt,even,stay-filled
up.i-have-no-idea-why-the-damn
thing-wont-stay-on!my-carb-is-a
600-double-pump,and-the-FP-i
ordered-is-a-110gph-holly-pump.
is-this-too-much-for-my-carb??
has-this-happened-to-anyone??
thanks-guys
88CRUZIN
damn-fuel-pump
Old Apr 20, 2003 | 10:25 AM
Vader's Avatar
Cruzin,
Why did you change the pump in itially? Had the old one failed?
You may not be getting fuel from the tank. The pickup strainer may be clogged with debris. You can remove the fuel tank cap, remove the supply line from the pump, and blow backward through the line into the tank to clean the strainer. You may have a filter near the tank as well.
Old Apr 20, 2003 | 11:28 PM
88CRUZIN's Avatar
hey,thanks,vader
imma,try,that,out,first,thing,in
the,morning.bout,the,pump,the,old
one,was,fine,i,just,wanted,to
upgrade,to,the,holly.one,thing,that
i,did,notice,when,the,car,was
struggling,is,that,fuel,was,leaking
out,the,base,of,the,carb.i,checked
the,float.level,and,it,was,fine.
also,the,carb,spit,out,lots,of,fuel
and,it,looked,as,it,was,flooded,out
through,the,barrels.WHATS,UP,WITH
THIS???AHHHH
but,thanks,man,im,gunna,check,that
out,as,soon,as,the,morning,comes!
88CRUZIN
Old Apr 21, 2003 | 12:23 AM
ronterry's Avatar
Car: '94 Corvette
The fuel spewing out of every orifice, clues me into thinking you have excess pressure, and it's holding the seats open - just flooding the **** out her...
Most carbs like Holley, Edelbrock or Qjet like 5-6psi - 7 tops. If your pump is dumping 8+psi you might have issues!
You might need a regulator, to keep that pressure about at 5-6psi
Ron
Old Apr 21, 2003 | 12:30 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Did your space bar break or something?
Old Apr 21, 2003 | 12:34 AM
88CRUZIN's Avatar
man,that,sucks,if,im,gunna,need
to,get,a,regulator,now.
i,just,checked,out,the,part#
on,the,pump,and,it,says,that,it
flows-100gal.at6-8psi.so,i,guess
im,gunna,have,to,call,summit
and,see,what,psi,it,is,for,sure.
if,not,anyone,wanna,buy,a,pump??
thanks,guys
88CRUZIN
and,oh,yah,my,space,bar,got
coke,spilled,on,it.haha
