Need help badly with non thirdgen, but OBD I
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
It's my 1986 Grand Am SE, 3.0 V6, Auto tranny, MPFI. It takes some cranking over and over and over again to get it started. When it starts it idles fine, when I push on the gas, it sputters and struggles to make any RPM's. I just checked the injetors and they all spec out at 16.1 being the lowest to 16.6 being the highest on the ohms meter. I thought maybe the exhaust was plugged up, so I gutted the cat Sunday, it still runs rough. What else should I check?
"Clear your mind, relax, and float downstream."
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
read the other topic, I elaborated more on what has recently been done to the car. Thanks to anyone able to help or comment
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
