Steering column
Old Apr 22, 2003 | 04:26 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Steering column
I have an '86 SC with tilt steering. I'm a bit of a tall guy and every time I get in to the car or I have to put my foot on the clutch I smash my knee on the steering wheel. The steering still works, and the tilt still works, but know the top portion of the steering column above the tilt is loose and it sort of rotates around. Any ideas on what might be broken?
Old Apr 23, 2003 | 03:20 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
common tilt column issue
i am not sure whether this is your problem or not, but it is very common with these columns (at least all of the ones so far in my families' vehicles)... The tilt assembly is bolted onto the main column with four external torx screws. when these are loose, it feels like the steering column is ready to fall off. you have to take the steering wheel off, then the lock plate, then the turn signal cam, then the ignition lock and the first plastic outer shielding (that holds the turn signal lever and ignition lock cylinder). then, if i remember correctly, you should be able to manuever a 1/4" 1/4" drive socket (this will fit and tighten the torx screws... i didn't have the correct socket for the small external torx) in to tighten them...
Old Apr 23, 2003 | 06:24 PM
Thanks, I'll give that a try. Hopefully you are right and nothing is broken.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
