8192 baud or 160 baud?
Old Jul 24, 2000 | 08:41 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Is the ECM in a 1986 Camaro p/n 1227165 a 8192 baud or a 160 baud serial data??
Old Jul 24, 2000 | 09:10 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
160 baud. It's covered on my website.
http://www.isthq.com/~dan/efi.html
Specifically, it's covered here: http://www.isthq.com/~dan/aldl_35.htm
"no one checks a private website unless you shamelessly promote it anymore"
Daniel Burk http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
[This message has been edited by ws6transam (edited July 24, 2000).]
Old Jul 24, 2000 | 10:50 PM
Brent's Avatar
I'm under the impression that the 165 starts at 160 and then switches to 8192.
All I know is my truck '747 ecm running at 160 displays data alot slower than my TA which has a '165.
Check out:
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
[This message has been edited by Brent (edited July 24, 2000).]
Old Jul 25, 2000 | 02:11 AM
Guest
Guest
Posts: n/a
8192
The 85 ECM is 160, but its a different PN too.
Old Jul 25, 2000 | 06:07 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
the '85 ECM is the older, 160 baud "870" computer that was used. In '86 they went to the 8192 baud "165" ECM, which is 51 times faster in collecting and transmitting diagnostic data. I just had my old 870 replaced with a 165 ECM and a custom burned prom. There are about 10 repinnings and a couple splices that are required, but the fact that I no longer had to use that god awful Burnoff module was enough for me to scrape up the money for the right parts. Details can be seen on my web page below.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
Old Jul 25, 2000 | 01:57 PM
Engine: 4.0L
OK, it's a toss up.
I got two votes for 160 baud and two votes for 8192 baud.
I need one more to be a tie-breaker :>
Old Jul 25, 2000 | 03:40 PM
calroc's Avatar
86 is 8192 baud
85 calif. iroc
383/A4
9" rear
Old Jul 25, 2000 | 06:41 PM
Engine: 4.0L
Looks like 8192 is the winner with 3 votes.
160 baud only got 2 votes. :>
Does anyone know for sure? I've checked about 50 sites looking and all they say is the older computers were slow 160 baou while the new 'puters are really fast at 8192.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
Old Jul 25, 2000 | 07:33 PM
Car: 1985 Trans Am
John the "165" computer is definately 8192 baud. I know from experience... trust me. I just had one put in my car. Your best bet would be to do the same. There are some repinnings that need to take place with which I had a lot of help but the swap was DEFINATELY worth it. Check out this link for all the details on how to do it... http://www.ece.udel.edu/~davis/z28/ecm_swap/
Kevin Irving
[This message has been edited by Kevin Irving (edited July 25, 2000).]
Old Jul 25, 2000 | 08:05 PM
Engine: 4.0L
Update, I just found a website that says straight out that the 1986 computer IS 8192 baud.
Here it is:
http://www.techedge.com.au/vehicle/index.htm
Old Jul 25, 2000 | 08:22 PM
ws6transam's Avatar
Could be that the ECM is 8192... My site info is taken from an internally published GM document, not from experience. It is a table of byte codes that I published before any of this data became general knowledge on the internet. I haven't updated it since, nor have many people offered feedback on the accuracy of the info.
Daniel Burk
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Pinguiclia
Oct 12, 2015 04:47 PM
Nervous2
Oct 8, 2015 10:53 PM
