bore clearance on AFR heads?
Old Apr 23, 2003 | 10:23 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Transmission: TH-700R4
I was looking into AFR alu heads and 190cc with i guess 68cc CB chambers are looken nice for $1250 shipped My Q is Thunder Racing has the heads and they said:
"Note 305ci requires 1.940-1.550 valves for bore clearance."
And the heads come "2.020 intake and 1.600 exhaust" standard. What should I get to get bore clearance for my LO3 and how much is it thanx guys
I should also mention i will get the heads after i get a new exhaust, headers, LT1 cam, intake manifold and 1.5RR.
SSBlueOx
Old Apr 24, 2003 | 12:08 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I wouldn't run those heads no matter what on a 305, plus the 6 8cc chambers will lower compression excessively!
Old Apr 24, 2003 | 05:40 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
ight then ill do everything cept heads till i get the 350HO that i plan to get in like 3-4monthes. Thanx just needed some info
SSBlueOx
Old Apr 24, 2003 | 05:42 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Should I just get my stock iron heads ported? And will the LT1 cam be good for ~40hp? thanx again
SSBlueOx
Old Apr 24, 2003 | 06:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The problem with a 305 and good heads, is that the bore is so small, that the valves aren't entirely above it. They tend to hang over the edge a bit. And when that happens, they smack into the top of the block when they open, instead of going down into the cylinder. Not suitable for racing.
Old Apr 25, 2003 | 08:05 AM
Vader's Avatar
Not suitable for racing...
You mean like a "poor-man's" splayed/canted valve setup? Where only the faces of the valves are splayed? Who needs all that expensive casting and machining, anyway?
evilstuie
Jan 9, 2020 08:29 PM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
