Guy's please tell me how to check for right timing tab (pointer)
Old Jul 25, 2000 | 08:10 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have a new replacment 350, and new replacemnet balancer from summit 6.somthing inches, and a balancer cover, I need to know how do I tell if I have the correct timing pointer on the car. The pointer that is on it now sits right up aganist the balancer and sits on the drivers side of the motor. Should it be there or straight yp on the timing chaine cover. I am not sure if I have it in the right spot or not. thanks alot joe The motor is a gm replacment 350
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Jul 25, 2000 | 08:15 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
All the GM crate motors that I've installed are timed at the drivers side location.
I'm not sure if all GM crate engines are there, just all the ones I've done are.
Everytime I put a crate motor in I buy a new balancer because the stock balancer doesn't time in the correct spot.
ASE Mechanic/Machinist/Smog Tech
RTKTGTR 1999 NBM T/A, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
[This message has been edited by Engineboy (edited July 25, 2000).]
crazeinc's Avatar
It should be on the driver's side of the timing cover and almost touching the damper....sounds like yours it perfect...
-'82 Z28 (Pro Street conversion in progress)
-'96 Grand Am (daily driver)
AIM me at: Unitedhope
ICQ me at: 77979548
Old Jul 26, 2000 | 06:31 AM
BLACK Z's Avatar
Car: 86 Z28
So when tdc is found the damper and the pointer should line up to 0?
Old Jul 26, 2000 | 08:50 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Yes.
GO #3
BRoss99
Aug 10, 2025 05:08 PM
midge54
Dec 27, 2019 04:14 PM
gwade12
Aug 8, 2015 08:17 AM
z28addict8490
Aug 7, 2015 08:48 PM
