vibrations at 2,000 to 2,500 any solutions
Old Apr 25, 2003 | 11:19 PM
radiateu2's Avatar
I know this has been asked many times by many people but, I havent found the solution to my problem.... I am refering to the car in my sig I have a vibration between 2,000 and 2,500 rpm. I have checked the obvious flexplate, balancer, mounts, and drive shaft weights etc...... has anyone came up with any other suggestions that might cause this. The vibration only occurs in the fore mentioned rpm range. Is it just a problem with sbc's. Anyone have a clue or suggestions on this feel free to reply?
Old Apr 25, 2003 | 11:28 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Ive got the same prob after puting a 350 in mine. My guess is that wshen I pulled the motor out and left the trans in, I messed up the converter. did u replace the trans or take them out together?
Old Apr 25, 2003 | 11:36 PM
radiateu2's Avatar
Hey shagme,
I pulled the motor and left the tranny and converter in. I did just have a thought thou. I recently had my I pipe welded in and I noticed that the muffler shop welded the pipe to the bracket on the transmission tail housing without and shock absorbing material. You know like a rubber hanger of some sort. I cant remember if it did this when I didnt have the I-pipe in though? My thought is maybe the I pipe is vibrating the tranny and I am feeling it in the car. On the other hand I thought I might hav felt the vibration throughout the rpm range
Old Apr 25, 2003 | 11:39 PM
SHAGME's Avatar
Car: 1988 IROC-Z
u know what I thnk mine is haning. thats and idea, no support. on the back of the trans right?
Old Apr 25, 2003 | 11:53 PM
radiateu2's Avatar
actually mine isnt hanging. It is actually bolted to the transmission via the old hanger.. what the guy at the muffler shop did was cut the hanging portion off and welded a flange to the pipe and bolted it to the transmission. There is nothing there to absorb the pulses and shock of the exhaust except for the transmission
Old Apr 25, 2003 | 11:57 PM
SHAGME's Avatar
Car: 1988 IROC-Z
ah I see that could be it.
Old Apr 26, 2003 | 12:05 AM
radiateu2's Avatar
I still think I would have fely it throuout the rpm range and not just this small range. What do others think? What do you think your problem would be Shagme, did you find any answers yet?
armybyrd
Sep 28, 2023 12:16 AM
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
