O2 sensor location
Old Jul 26, 2000 | 07:49 PM
Ben87GTA's Avatar
O2 sensor location
ok, i know the sensor is on the exhaust manifold (drivers side) but is it accessible from the top? i see something that Im pretty sure is the sensor..but not quite sure if its it. (are there two sensors on l98's? i know my friends Neon ACR has one for upstream and downstream..) If anyone has a pic it would be worth a 1000 words... thanks
-ben
1987 5.7L L98 GTA-
Current Mods: Gutted Cat, !MAF screens, Gutted Air Box. K&N, Ram Air, Throttle body coolant bypass, AIR system removed, 3" pipe to flowmasters, dual 12" electric fans, 4 core alum radiator, 160* stat, high output h20 pump and alternator, Accel Cap, rotor, 8.8mm wires, Bosch Plats, AFPR, Performance chip(unknown kind), Nitto NT555r 245/50/16 drags rear, Yokohama Advan 032r 245/50/16 fronts, JVC KDSX939 Head unit, Kenwood Excelon 4x6's, Kenwood Excelon 4 way 6x9's, Kenwood 606c amp, Power Acoustic Crossover, 2 JL 10w0's in custom bandpass box.
Best Run: R/T .601; 60' 2.010; 330' 5.990; 1/8 9.154@76.89mph; 1000' 11.997; 1/4 14.489@ 96.78
(only mods at that time were the K&N, exhaust,chip & no drag radials)
#077 Central Florida F-Bodies (http://www.cffb.com)
Old Jul 26, 2000 | 10:02 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Should be just one....located on the pipe, not the manifold...I use about a 12 inch extension and a O2 socket, the ratchet then comes out about at the front of the valve cover (in reference) makes it real easy to get out and in.
Nick McCardle
Sep 10, 2015 08:36 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
