brand new GM block
Old Apr 26, 2003 | 05:15 PM
BigL350's Avatar
brand new GM block
Does a brand new GM block require machining at all? I'm wondering if the cost of a new block would cancel out the cost of machine work+cleaning/prep+core charge. A new 4-bolt, 87-up, 1-pc RMS goes for around $600. What do you guys think?
Thanks,
Larry
Old Apr 26, 2003 | 05:19 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
depends what you want to do with it.. but for a basic build up it shouldnt require machining
Old Apr 26, 2003 | 05:47 PM
BigL350's Avatar
I just bought a ProCharger D-1 supercharger kit for the malibu in my sig. I tore down the motor this week, and it's only a 2-bolt, stock rods, crank, and pistons, and it has already been bored .040, so there really isn't anything I can reuse. Now I need to build a short block to handle the blower, and I'd like to stay with a newer style block so I can use an oem-type roller cam. I plan to use a stock stroke Eagle forged crank and 6" H-beam rods, and SRP blower pistons. I'd like to keep the whole assembled short block under $3000.
Old Apr 26, 2003 | 06:33 PM
87daddyformula's Avatar
Car: Formula
Engine: 5.0L
Transmission: 700R-4
Ok, yes you will need to have the block machined because there is a lot of places where even an after market block needs to be optimized...such as oil passages, combustion chamber characteristics, air flow passages, and proper fluid movement (coolant). If you fully prep the block with supercharging in mind there shouldn't be any reason why you can't get about another 50-100hp out of your engine; as oppose to just putting it together as is. There are always benefits to be had from prep work...wether it be more power, longevity, or drivability. You'll probably find that anyone who says otherwise probably isn't getting the most out of thier engine. Just my $.02
Old Apr 26, 2003 | 07:20 PM
rezinn's Avatar
Air flow passages and combustion chambers? He's talking about a block here.
Old Apr 26, 2003 | 07:39 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i do believe they are already prepped and if anything may require just a hone. if someone is finding a combustion chamber in a small block chevy, they are looking at it wrong let alone finding airflow anything other than the bore.
my86bird
Oct 23, 2015 12:20 PM
Jorlain
Oct 8, 2015 01:57 AM
Reddeath210
Oct 6, 2015 08:20 AM
New2Chevy
Sep 28, 2015 12:35 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
