96 4x4 Ram rotor removal question
Old Apr 28, 2003 | 05:37 AM
Z28Clone's Avatar
I removed large hub nut and back 4 hub bolts. I can't get the hub and rotor to come off. Do I need to disconnect the ujoint? Should I knock out the studs then remove the hub separate from the rotor?
Old Apr 28, 2003 | 06:08 AM
ede's Avatar
ede
never worked on one so this is really a WAG, but i'd suspect you need a puller. is the axle splined thru the hub? if it is you'd need a puller. do you have a manual? i'd guess not since you're asking this. ought to buy a manual for it, it'll make life a lot easier for you.
Old Apr 28, 2003 | 10:59 AM
Vader's Avatar
Dodge RAM? Give it a few more months and it will probably rust off and come up through the hood (read the recall/TSB list for those "tough" trucks - that part about the front suspension rusting apart).
I think you're going to need to pull the hub on that one. Is that an Eaton front axle?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
