Question about 041X heads
Old Apr 28, 2003 | 03:08 PM
Gator_Z28's Avatar
Car: '86 Z-28
Engine: 355
Does anyone know the flow data on these heads? I've done tons of searches and I can find anything but
69-70 302 or 350
1.94/1.50 or 2.02/1.60 valves
64cc Combustion chambers
165cc Intake and 65cc Exhaust
I'm woundering because I know a guy that is selling his for $120 and I want to know if it is worth it. I have 882 heads on the car now.
Old Apr 28, 2003 | 03:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are typical old double-hump heads. THey flow a ton better than 882s. IIRC they have the accessory bolt holes, so you can acutally install them in your car.
For $120, they're not a bad deal, if they're not in total need of everything. Things to look for include: set up for screw-in studs and guide plates, which should include accommodating 1.6 rockers; are they cut for bigger springs; are they set up for better valve guide seals; what valves are in them; what port work have they had; what hardware comes with them.
I would not particularly advise spending wads of money on them though; like any old stock casting, by the time you have them all worked up, you'll have almost as much money into them as a good set of new aftermarket heads that will considerably outperform them.
Whether they're a good deal for you depends on what you intend to do with them, as well as what's been done to them.
Old Apr 28, 2003 | 05:14 PM
Gator_Z28's Avatar
Car: '86 Z-28
Engine: 355
I don't intend on doing much with them. I just want something that will flow better and raise my compression. RB83L69, you don't so happen to know if they well work with my Headman shorty headers?
Old Apr 28, 2003 | 05:22 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes they should work with you headers.
Old Apr 28, 2003 | 05:26 PM
Gator_Z28's Avatar
Car: '86 Z-28
Engine: 355
thats good! thanks
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
