questions about head machining....
Old Apr 30, 2003 | 10:56 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
ok.. i have decided to buy a l98 shortblock and go over my 383 when i get some extra dough...... right now things are tight and i have to get a gm so i can make payments on it.....
i have afr 190's that i want to get milled to 64cc so that i can keep the compression resonable to have good thermal effecincy.....
do you think that 9.3 to 9.5:1 is ok with a comp xe282hr cam and aluminum heads? would i need say about 10:1 to compensate for the lumpy cam?
i figured 9:1 would be resonable and let me run some good timing on 93 and avoid detonation.......
whats your thoughts?
Old May 1, 2003 | 10:15 AM
Vader's Avatar
What pistons are you using?
Old May 1, 2003 | 11:08 AM
badgta's Avatar
Car: 1991 FORMULA
ooh
i' a factory l98 shortblock new from gm... i figured i'd go ahead and get it, and work on the 383 when money permits.. that way i would have a spare engine ready to go......
i was kinda worried about piston to valve clearence also...... when you cut the head you are letting the valve get closer to the piston.. aibet not real close but closer......
i figured with a 64cc chamber, and a felpro 1003 head gasket, the compression would come in right around 9.5:1..... well in the limits for 93 octane and a 100 shot of nitrous...
Old May 1, 2003 | 06:33 PM
ede's Avatar
ede
i wouldn't machine heads as a way to raise compression, i'd also not run a power adder on a stock l98 short block.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
