Tensioner, ac/compresor, airpump bracket
Car: 91 RS
Engine: 350 H.O.
Ive noticed a rattling coming from my engine compartment so I go to check it out, and it turns out be this bracket. The problem is the top 2 bolts that hold this bracket into place, have snaped. My problem is how do I get these bolts out of the heads, they're snaped perfectly even with the heads. Any help is highly appreciated! Dont want to brake the bottom ones too!
Car: 1991 Camaro Z28
I'm sure someone else might have a better idea, but here is the best I came up with.
Take the bracket completly off, and use a screw extractor and see if you can get it out, if not drill it out a retap it. Not much else you can do.
