ATTN: AZDave
Old Jul 28, 2000 | 03:27 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
ATTN: AZDave
Thanks for the info. I also decided to live with it for a while but I'm tired of hearing it. In your case,does the sound seem to center around the cat as well? I've also thought that it was due to the way the 2 pipes were "squeezed" together to form the union to the cat. I've suspected that the knock sensor was picking this up as well,which is hurting peformance. Have you tried to have the Y pipe rebuilt? My brother and I put the exact same exhaust system on his 91 Formula(headers,cat and catback identical) but his didn't have the noise. What's your setup? Maybe there's a part other than the exhaust that could be causing this. I'm planning to change the torque converter and flexplate for 2 reasons. One to eliminate the possibility of that being the problem and two,because I've wanted a higher stall for some time now and it gives me a good excuse with the wife.Can you help any further?
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,3" high flow cat with SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
N.J.-SLICK-1
Aftermarket Product Review
Jul 31, 2014 09:15 AM
FatOldBastard
Jan 19, 2010 12:26 PM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
90TA
Jan 20, 2003 09:05 PM
