Car Loses Power Then Comes Back ?
Old May 5, 2003 | 11:09 AM
NEOMASTERZ28's Avatar
Car: 85 z28
SOMETIMES WHEN I ACCELERATE I GOT THE PETAL HALF WAY DOWN , YOU CAN FEEL THE CAR PULLING, THEN U PUSH IT 3/4 THE WAY DOWN , YOU CAN FEEL HER STOP PULLING LIKE SOMEONE TURNED OFF THE TQ AND HP AND THE RPMS JUST GO UP WITH NO PULLING POWER THEN IF U PUCH IT SOME POWER COMES BACK BUT STILL WEAK .THIS IS LIKE THE 4TH TIME IS DONE THIS
CAN ANY 1 RELATE TO THIS ?
Old May 5, 2003 | 03:04 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hmmm
id liek to know the answer to that also. my guess is if it did it all the time that maybe the intake on it an dthe cam werent that good for after half throttle.
Old May 21, 2003 | 10:38 PM
scuzzy's Avatar
I can relate to something similar...
the 700R4's stock from the factory only have a lifetime of about
102K miles, then they start to fail, generally symptoms of
failure is 'slippage'. or basically where the car stops pulling, but
the rpm's climb quickly.
The slippage I experience is between gears, between a shift
(automatic transmissions). if I've punched the gas and I ride
it all the way till the shift, it'll redline the tach, and slip craizly,
though all the gears.
if you're pushing it 3/4ths the way down, and it's not ready to
shift, then it might downshift, which is where the slippage comes
in.
just depends, 102K miles is average lifespan for a 700R4, getting
them rebuilt only delays the problem for a short period, you're
better off getting a TCI streetfighter tranny or something similar
which is built with performance in mind.
this is all automatic transmissions, btw.
(just reading over the old posts and thought I'd post some comments
on them)
Old Jun 2, 2003 | 06:38 PM
Car: 85 z28
its a new 700r4 with shift kit
Old Jun 2, 2003 | 07:32 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
It sounds like a tranny problem. If you had someone else install it I would take it back to have it checked out.
Does it rev smoothly when in 'Park'?
midge54
Dec 27, 2019 04:14 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
jharrison5
Aug 19, 2015 05:53 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
