what are tie rod torque specs?
Old May 7, 2003 | 03:20 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
whats the proper torque spec for the tie rod to spindle and tie rod to center link for both sides?
Old May 7, 2003 | 05:35 AM
ede's Avatar
ede
never torqued them, use impact if i can, other wise i go for the real damn tight method. WAG for a torque spec would be in the 35 to 45 ft/lbs range.
Old May 7, 2003 | 09:24 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i know the tie rod to spindle is held in with a clip so just get them tight enough to slip the clip in the hole and spread the ends and its done. the centerlink to tie rod i have no clue i cant even get my nut on without the rod spinning on me. any helps on that one?
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
