distributor removal and installation, TPI
Old May 7, 2003 | 10:59 AM
Kaps's Avatar
I need to pull my distributor to change my intake manifold on a 88 GTA TPI. Did a search and found stuff for a V6 dont know if anythings diffrent. My Haynes manual is crap tells me to undo the bolt and pull it out, must be more indepth than that. Any tricks/tips/warnings about doing this? As you can tell I never pulled the distributor out and feel VERY uncomfortable about doing so. If the distributor doesnt go back in exactly where it should, what would happen/take to fix it? Thanks
Old May 7, 2003 | 11:18 AM
ede's Avatar
ede
you can note/mark the location of the distributor body and the rotor and r&r it as it sits or bring it to compression stroke on #1 before doing the r&r
Old May 7, 2003 | 12:31 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Yeah just mark the distributor as stated above and you'll be fine as long as you don't bump the motor over. Disconnect the battery so you don't accidentally crank it over. Once it's in verify timing just to make sure it's correct, but this should get you almost exactly where the dist used to be.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
