bent flywheel
Old May 8, 2003 | 06:06 PM
camaro_1983_383's Avatar
bent flywheel
well, after having bad vibration, i checked out my flywheel with the engine running, and i can see that it is bent/warped. at the teeth it looks to have about a 1/4" of movement. would this cause an awful vibration? if so, how hard is it to change one. i also would like to change my torqu convertor at the same time. do i have to pull both the engine and tranny or neither? its a 383 and th-400. thanks
Old May 8, 2003 | 06:19 PM
Steve86TA's Avatar
Car: To many to list
You have to pull the trans.Fairly easy/straight forward job.Be sure not to over torque the bolts when you put it back together though.
Old May 8, 2003 | 09:34 PM
what if i just want to change the TQ convertor?
Old May 8, 2003 | 10:00 PM
quicklil87lt's Avatar
you would still need to drop the tranny. the torque convertor slides over the input shaft on the tranny and the only way to get it off is to slide it off.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Zell1luk
Sep 29, 2015 10:36 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
