1.6 roller rocker ok with stock push rods?
Old May 8, 2003 | 08:59 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
I 've had the LT4 hot cam kit for about 3 years havent had time to put it in. So I thought I would put the roller rocker in with the springs But can remember if the stock push rods will work thanks for any info.
Old May 8, 2003 | 09:27 PM
88 IROC BOB's Avatar
I just put in Crane Gold 1.6's. Had to use a shorter pushrod to keep the correct geometry. I think it was about .050 shorter.
Bob
Old May 9, 2003 | 09:08 AM
Vader's Avatar
Shorter? You must have milled the head bosses lower than 0.200" or have different heads?
Old May 9, 2003 | 10:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
99.999% of the time you don't have to change them. The reason you would need to change the push rods has to do with changing the cam. As long as the cam is the same, and the rockers are made to stock specs as far as the height of the push rod seat, then the push rods will not need to change.
Old May 9, 2003 | 10:57 PM
Raiden's Avatar
I agree with vader. I put the stamped steel 1.6 roller rockers (think they were the crane gold series) and my vlave guies went bad after 10K miles. I even used a push rod checker for the correct geometry and it verified good with a .050 shorter push rod.
Old May 10, 2003 | 09:53 PM
pheonix305's Avatar
Car: 1986 Trans Am
Engine: built 305
Transmission: 700r-4 shift kit
so what do you need to do if you use 1.5 roller rockers with a aftermarket cam.
Old May 10, 2003 | 11:25 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
nothing, unless you have an insainely radical cam...
midge54
Dec 27, 2019 04:14 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Reborn756
Sep 4, 2015 03:42 AM
IrocZ'85
Aug 17, 2015 06:24 PM
happyhapka
Aug 15, 2015 04:42 PM
