tensionsor arm .. help!
Old May 12, 2003 | 09:06 AM
ShaneBuss2's Avatar
Car: 1992 Firebird Coupe
Engine: 357ci Carb
Axle/Gears: 3.73 posi, stock rear
hey guys i have a 92 firebird. here is my prob.
my tensioner arm is coming undone (where the spring is). the actually pully is ok.
this things looks like a PITA to change.
ANy ideas or advice? i cant seem to make it stay on so i would like to replace it. I hope i dont have to replace that entire acessor bracket.
thanks,
shane
Old May 12, 2003 | 11:42 AM
Vader's Avatar
SB2,
The belt tensioner is about a $35-45 item at most parts stores. It's easier to change than a water pump.
NAPA P/N NBH-38118
Old May 12, 2003 | 11:54 AM
ShaneBuss2's Avatar
Engine: 357ci Carb
thanks vader!
im trying to find a pic of this so i can make sure its the right thing..
how did you know the napa p/n? there isnt a napa anywhere near me, but im sure i can cross reference.
thanks again!
Old May 13, 2003 | 10:45 AM
Vader's Avatar
This is on a '91, but it should be close:
Old May 13, 2003 | 11:14 AM
ShaneBuss2's Avatar
Engine: 357ci Carb
that is correct. the tensioner ARM has come off, the pulley is fine.
is that part # he refrenced still what i need?
thanks guys!
Shane
Old May 14, 2003 | 02:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
http://www.napaonline.com ; put in your car details, it's under "Belts & Hoses", then under "Belts".
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
