Need some help
Old Sep 12, 2000 | 11:59 AM
submissive70's Avatar
Need some help
I have a 92 Z28 and the third brake light keeps going out, I went to replace the bulb but it was fine. Then I went looking for the fuse and for the life of me could not find it. If anyone can help me figure out what is wrong with this thing I could use the help.
-Thanks-
1992 25th anniversary edition Z28 (Black W/Red stripes) 5.7 L98 engine, 3.73 gears,
Aluminum under drive pulley's, Gutted air box, K&N air filters, Air Foil, Bosch platinum spark plugs,
8MM spiral core wires, stage 2 chip, engine oil cooler, soon to have a high flow cat with a 3" flowmaster exhaust and P7000 Perelli Z rated tires all around.
Did I mention the interior is fully loaded!
Old Sep 12, 2000 | 12:19 PM
Mike 25th's Avatar
Can't really help you out, but I was curious where in MA you are from. I would love to see your car sometime. I have one very similar and was thinking of adding red stripes. Do you have red interior? Are your wheels accented in red?
Sorry this has nothing to do with your problem, but thanks for listening...
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
