Lt1 Intake - Injectors ?
Old May 25, 2003 | 06:22 PM
Tyler-88's Avatar
i was planning on using ford SVO 30# injectors. if i remember correct, ford is actually more lbs than what their rated at. but i was thinking, which set of SVO injectors will fit, or are they all the same? should make 500hp NA, but with a 150 shot, should i bump up to the 36lb'ers?
Old May 26, 2003 | 09:05 PM
Damon's Avatar
The SVO injectors are a bolt-in. Ford rates their injectors at 37 PSI, GM rates at 42 PSI. SVO 30s are about equivalent to a GM-rated 32# injector.
I would think they would be barely sufficient for 500HP at the flywheel, naturally aspirated. They worked just fine and had plenty of "headroom" left at ~425 HP (flywheel) the one time I used those particular injectors.
If buying used please DOUBLE CHECK they are actually the injectors they are supposed to be. Bought a set once that were supposed to be SVO 30s but were actually 24s. Had me scratching my head for months trying to get the tuning right.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
hayesaw0210
Aug 23, 2015 11:15 PM
