crankshaft questions
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
What's the difference in the crankshaft from a 2pc rear main and a 1pc rear main? can i use the eagle SIR rods on the newer crank or are they a 2pc rear main only type deal. these are the rods that my father is using on his pre-86 355. i, however, have a 91 350. any and all help will be appreciated.
also, what would ya'll suggest for an aftermarket harmonic balancer? any comments on the ati or fluidamper?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Crank
The rod and main journals are the same on 1 piece and 2 piece cranks. The Fluid dampner is a good one. Not sure on the ATI but if it is SFI rated then it is ok too.
Car: 4
Engine: 6
Transmission: 5
Rod journals and main journals are the same. The only difference is how the rear main seal goes in; in the 2-piece design it's (duh) 2 pieces, one goes in the block and one goes in the rear main cap, and the flywheel flange is much larger than the main bearing; on the 1-piece design, there's an aluminum seal housing, and the seal is a steel-clad lip seal like for a wheel bearing or something, and the flange where the flywheel goes is flat and much smaller than the 2-piece design. The 2 types have about the same sealing effectiveness. GM switched purely on the basis of assembly cost.
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
