My 4th gen seats have no seatbelt guides...how should I do it??
Old May 29, 2003 | 01:11 AM
CamaroX84's Avatar
I have a set of black/gray fourth gen seats, and they have no seatbelt guides in the headrest, and I'm tired of driving with the seatbelt almost on my neck. I'm guessing the seats got re-covered or something, because there aren't even holes in the fabric. So how should I go about installing them on there? I'm guessing there's some kind of metal bracket in there, right? If so, should I just run a long self-tapping screw in there or what? Thanks in advance.
Old May 29, 2003 | 01:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Use a long needle to find the screw holes. Most of the headrest on the side is pretty hard so you should be able to locate the screw holes with this method. Seatbelt retainers are less then $7.00 each from the dealer, just need the right ones for your seats. It sounds like you have the 1 piece Camaro seats, and not the trans am seats with the movable headrest.
Old May 29, 2003 | 06:54 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
If it'll help any, I've got pics of mine at https://www.thirdgen.org/techbb2/sho...hlight=deemax. That should at least give you a good idea of where to start poking around. Mine are out of a 94, but I suspect they're all the same.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
