Fuel pump relay?
Old Sep 12, 2000 | 06:22 PM
IROCracer's Avatar
Fuel pump relay?
While back, I got a code 54 (low fuel pump voltage), nothing seemed wrong. Lately, when I'm driving, the car will lose almost all power and stall out if I mash the throttle then die. Fuel pump is less than 2 years old. Think it's the relay? If I try to start it right after it dies, it'll carnk and try and sputter and die. If I wait 5-10 minutes, it'll fire right up and make it another few miles before doin it again. It's not a frequent occurance, but it's still there.
Thanks for any help.
Kelly
If you've gotta fix it, fix it better than stock.
Old Sep 12, 2000 | 06:28 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
That sounds like a bad fuel pump, but it could be the relay. Maybe a bad connection somewhere..
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Old Sep 12, 2000 | 06:39 PM
IROCracer's Avatar
Where are the connections? Tell me there isn't one bolted to the starter solenoid. Yup, bet there is huh. Grounded out a wire there, had to replace the fusible link. But that might have screwed up the relay ya think?
Old Sep 14, 2000 | 07:18 PM
IROCracer's Avatar
OK...new news. Whenever it stalls on me, and I get it started and try to go forward, my car says "Sputter, sputter, GAG" ok ok, it just sputters and dies. However, if I put it in reverse, the thing runs fine, had to drive 3 miles home in reverse yesterday.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
