How much vacuum should it have?...
Old May 30, 2003 | 08:21 AM
RPO-B4Z's Avatar
Car: 1989 IROC-Z 72Kmi.
Axle/Gears: 2.77 aussie 9 bolt
How much vacuum should I be seeing while the car is idling. I am taking the reading off of the port that supplies vacuum to the fuel pressure regulator. I'm getting maybe 14Hg. My car is shuddering (worst at 1500rpm). Can't pinpoint the cause.
It's an 89 IROC L98.
Old May 30, 2003 | 11:38 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Not sure what the magic number is but I get 17 with the stock cam. 92 L98
Old May 30, 2003 | 12:04 PM
CamaroX84's Avatar
Try taking the reading from a different spot. Now I'm not sure if this applies at idle or not, but you may need the vacuum for the fuel pressure regulator to be working to it's fullest effect and to get a proper vac reading.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
