one more qs on fuel pumps
Old May 31, 2003 | 08:20 PM
rino fabrizi's Avatar
91 z-28 parked car this morning got back it started it up very low rpm's would not rev after 3/4 times of this wouldn't start at all assuming it's the pump i've checked ign got a good shock from #1 wire qs is there only 1 relay 5 wires located on the drivers firewall i've put the wire on the ecm connect and no noise is there anything else to check i've checked the 2 hard lines coming from the back only drippings from the bottom line
Old May 31, 2003 | 09:12 PM
25thanniversZ's Avatar
check all grounds including the ones on the back of the engine...any codes???
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
