Power Steering Pump switch?
Old May 31, 2003 | 10:16 PM
RS91's Avatar
My pump is equiped with pressure switch. Is it okay to by pass this switch? What is it for?
Old Jun 1, 2003 | 09:50 AM
Vader's Avatar
RS,
Under higher steering system pressures, the switch will cycle off the AC compressor so that the excessive load doesn't stall the engine while steering aggressively and running the AC simultaneously. Without it, you could stall while trying to parallel park with the AC on and engine at idle.
Old Jun 1, 2003 | 10:48 PM
RICHRAD's Avatar
Good to know....wondered why there was wiring going to the steering
Old Jun 1, 2003 | 11:34 PM
RS91's Avatar
I no longer use my AC. Can I disconnect this switch?
Old Jun 2, 2003 | 11:34 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
It's been disconnected in my 92 for over a year now with no problems, so disconnecting it won't hurt anything.
-Rich-
Old Jun 2, 2003 | 06:33 PM
RS91's Avatar
Thanks guys...
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
