ok anyone know where fuel pump relay is located?
im thinking when i put the new relay in i put it in the wrong spot or somthing. does anyone have a diagram or chart i can see? i looked in my haynes and they dont even mention it. Thank you
Nicole
Nicole
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
have you also checked the fuel pump fuse? over by the battery.
http://www.fl-thirdgen.org/componentlocator.html
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Usually located under the hood, mounted to the firewall in front of the driver side at the very top.Should be maybe 2 other relays right beside it. At least in my 92' that's were it's located.
it fit though it was furthest to the right and mounted to the firewall on drivers side
