I Need Your Opinions On Bf Goodrich Comp G-force Ta Kdws Tires
Old Jun 5, 2003 | 07:05 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
I will be getting some bf goodrich comp g-force ta kdws tires for my 84 z. I had a set of kumho's on the car, but they are worn out after only 15,000 miles. I had them rotated and serviced every 5,000 mile also. They wore flat across, just wore out way too fast. So, now I am looking at gettin the bfg's and wanted to get some fellow f-body members opinions on them. What kind of wear did you get out of them, and also how do they handle. Thanks in advance. Jason
Old Jun 5, 2003 | 07:18 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Great tires, I love them. I ran a 2.023 60' on a L98 GTA. Only mods were a 3" exhaust and 1.6 rollers so a stock L98 should expect the same, or close to it.
Old Jun 5, 2003 | 09:20 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Everyone I have heard from say they are very sticky, but I want to know how they last. I am not trying to pay 600-800 bucks a year for tires. I only got 15,000 miles out of my kumhos. They stuck like hell, wet or dry, but didn't wear worth a dam.
Old Jun 5, 2003 | 09:22 PM
FruityOne's Avatar
I've only had mine for about 1,500 miles now and they look like they are wearing fine. They have a larger tread depth than most tires, and wear is even right now.
Old Jun 5, 2003 | 09:43 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
My friend just got a new set of tires because his G-forces only lasted 20,000. Sounds like these aren't the tires you are looking for. He also rotated every 5000 miles. If I bring up the subject of G-force tires he starts to cuss and swear.
Old Jun 5, 2003 | 09:47 PM
25THRSS's Avatar
Ive got em and i think they are great for an all season tire. If I had to do it over again I would have gone with the KDW though for the little extra traction, but for an all season tire they are great.
Old Jun 5, 2003 | 09:56 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
So what does he run now.
Old Jun 5, 2003 | 10:07 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Some type of Cooper Tire. They don't hook like the others but they are supposed to last 50,000 miles if rotated correctly.
Old Jun 5, 2003 | 10:15 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
are you sure his was the kdws and not one of the others, because they others have a lower tread wear number???
Old Jun 5, 2003 | 10:24 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I don't know what kdws is but all I know is that they were BF Goodrich G-force tires. The salesman told him that they would last at least 45,000. This is on a 95 Z28 that is a daily driver. Not one that he drives on weekends and does burnouts at every stop sign.
Old Jun 6, 2003 | 02:51 AM
Dan88IrocZ's Avatar
I have KDW's on the front, with BFG Drag Radials on the rears.
The KDW's handle great, but the treat depth is huge and I wish I could put'em on the rears and burn'em down to acceptable size
Old Jun 6, 2003 | 10:28 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have the KDW and they are awesome tires, but they are a softer compound and seem to wear pretty quick. Got less than 20K or maybe less than 15K on them and they wore down to almost a slick.
I also have the Kumhos Supra 712's, they are decent tires when it is warm outside, but when it's cold, they don't grip that great.
They lasted a over 20K.
Old Jun 6, 2003 | 10:29 AM
Zepher's Avatar
delete. Double post
Old Jun 6, 2003 | 02:19 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
the KDW IS 300 TREAD RATING, THE KDWS IS A 400 RATING. I think there should be a big difference between the 2.
Old Jun 6, 2003 | 08:15 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
http://www.tirerack.com/tires/Spec.j...orce+T%2FA+KDW
http://www.tirerack.com/tires/Spec.j...rce+T%2FA+KDWS
Here is the difference in the KDW & the KDWS. There is 100 difference in the tread wear numbers. I think the KDWS should last alot better. My kumho's are 280.
Old Jun 6, 2003 | 08:16 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
oops triple post
bad84z's Avatar
Car: 84 Z28
Engine: 355
sorry
Old Jun 7, 2003 | 12:21 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Anyone running the KWDS and not the KDW. I want to know about the wear time on the KWDS which is 100 greater than the KDW. THanks Jason
Jorlain
Oct 8, 2015 01:57 AM
2MNYMaros
Sep 15, 2015 11:36 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
Jlanz55
Sep 8, 2015 11:28 PM
TheExaminer
Sep 7, 2015 08:34 AM
