oil pressure gone crazy!
Old Jun 6, 2003 | 02:02 PM
1bad89bird's Avatar
hey guys iam new here so go easy!, my oil pressure is iradic whene iam on the highway it sometimes pulls past the 60 mark and the needle flutters ans sometimes whene iam at idle it goes to about 18 mark this happens more often when i have the air conditoner on but it can also happen when i dont. This also doesnt happen all the time but its getting more often.
Old Jun 6, 2003 | 02:03 PM
1bad89bird's Avatar
by the way its a 305 tbi
Old Jun 6, 2003 | 03:57 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Wrong forum, but mine does this as well. It is most likely the sending unit that is shot. If these engines were actually running up and down that quickly you would have some serious problems.
Old Jun 6, 2003 | 07:34 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Mine does it too....
Old Jun 7, 2003 | 10:04 PM
Chuck Haynes's Avatar
oil sending unit
Old Jun 8, 2003 | 12:09 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yup, i agree.. mine does that too.
Old Jun 8, 2003 | 08:07 AM
ede's Avatar
ede
oil preasure is rpm dependent and also changes as the oil heats up. 10 psi per 1000 rpm is acceptable. as already said you may have a problem with the sender or the factory gauge ,neither are known for great accuracey or reliability.
Old Jun 8, 2003 | 08:51 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
mine does this too although it never has gone past 30 psi. it drops more during long periods in traffic. what are the signs that your oil pump is failing? does it just go or does it waver like this?
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
