throttle response
Old Sep 19, 2000 | 10:03 PM
ZDADDY92's Avatar
throttle response
a buddy of mine has a TA, with the 305 TPI. Motor runs good once u get it running, but it has a rough start, and when you floor it, all it does is cough, with no real acceleration burst. Any info would be greatly appreciated.
92 Z-28
305 -5speed
160 thermo.
K&N Air Filters
B&M Ripper
14.7 @ 96mph
Old Sep 19, 2000 | 10:32 PM
Vader's Avatar
Daddy,
Just the standard-issue stuff - check ignition and plugs, TPS adjustment, IAC cleaning, check minimum air position, check fuel pressure, set base timing, scan for codes. If the car is older (what year is it?) and has a MAF sensor, check the intake ducts for cracks and leaks. My guess is that if the ignition system is sound, you're a little lean from heat, intake leaks, or poor injector flow/spray pattern.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
