sensor location
Old Jun 8, 2003 | 07:43 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
sensor location
o2 sensor location
I have Hedman longtube headers on my car, I did not have an o2 sensor bung put on the header before I installed them. I also have a custom made Y-pipe, can I just have the o2 bung put onto the Y-pipe right behind where it connects to the header instead of putting it in the header? The reason I ask is because the Y-pipe is currently off the car and it would be easier to take it somewhere and have it welded to the Y-pipe than either dropping the header back out or trying to get it in the header with it on the car. I already have the connector to run a heated o2 sensor so I would think it would be fine. Another question, if the o2 sensor requires a special o2 extention wire, how do I go about hooking the wire from the heated o2 sensor connector to the original o2 wire? The connector just has three wires coming off of it with bare ends.
Old Jun 8, 2003 | 08:10 PM
Morley's Avatar
Yes a heated O2 sensor would work fine in that location, just make sure it is out of the way of road debris and speed bumps.
No special wire is needed to hook it up.
Nick McCardle
Sep 10, 2015 08:36 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
