Question on Carrier size, please help
Old Sep 21, 2000 | 02:23 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Ok, my friend has a 93 5.7L 350 auto trans, now what kind of gears does he have and what size carrier? Thanks a lot guys.
Old Sep 21, 2000 | 09:09 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Your buddy has a 10-bolt carrier with a 7.625 inch ring and 28 spline axles. That carrier will bolt into any 10-bolt housing including the 1982-1992 F-body and the S10 truck line. Earlier models (up through 1988 or 1989) used 26 spline axles, so the successful installation into an earlier generation axle housing requires a different set of axles.
See my webpage where I install a 1999 Firehawk heavy-duty Torsen differential into my 1984 axle housing.
http://www.isthq.com/~dan/10bolt.html
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
New best E/T! 14.400 at 98.6 MPH in 88 degree air at Stanton, Michigan.
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
