Edelbrock Heads and Manifold question?
Subscribe
Sep 20, 2000 | 04:03 PM
I have the Edelbrock 6085 heads and the Edelbrock hi-Flo mainfold on my L98 350. At the time, the Hi-Flo runners from Edelbrock were seriously backordered. I purchased SLP runners instead.
My question is: Am I starving my motor by not using the Edelbrock runners with this setup or will I be OK with the SLP? I also have a 58mm Edelbrock TB on the plenum and the plenum is mildly ported near TB openings.
Reply 0
Sep 20, 2000 | 06:21 PM
SLP Runners SUCK Get the Edelbrock ones.
Reply 0
Sep 20, 2000 | 06:33 PM
No, you're fine with the SLP runners. The Edelbrock runners suck even worse than the SLP ones do. If you really want the best runners, check out AS&M.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
Sep 22, 2000 | 11:02 AM
Do I need to port the SLP runners to the edelbrock manifold or can I leave them alone.
Does porting the runners to the plenum make a large difference in HP?
I might order the wide mouth gaskets from TPIS and port them, but I thought I would ask before I go through all the trouble to port.
Reply 0
Subscribe
