Speedo not working after gauge cluster swap..
Old Jun 12, 2003 | 04:52 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I just swapped out the 110 speedo for a 145 speedo in my '90 Iroc but the new speedo isn't working. It's not totally dead, it'll read 10-15 mph when I'm actually going around 40 or so. Everything else seems to work fine, tach. seems pretty good, other gauges work, lights light up.
What could cause only the speedo not to work properly? Do I need any other parts to make this swap function properly? How should I go about trying to make this work?
Thanks.
Brian
Old Jun 12, 2003 | 06:24 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Did you change you speedo gears in the transmission? If not I think you need to. You could get a reprogrammer. I think in plugs inline with the speedo cable. Just replacing the speedo gauge doesn't work.
Old Jun 13, 2003 | 08:54 AM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Is that right? I can't see that there would be two sets of tranny gears for each rearend gear ratio, 1 for the 110 speedo and 1 for the 145.
Old Jun 13, 2003 | 03:15 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Any other thoughts on this? Is freeman right?
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
